I posted regarding this issue a few months ago. I inherited a Central Boiler when I purchased my home outside of Boise, Idaho last year. We didn't use it last winter as we were at the house sporadically, but we now live here full-time and began using the Central Boiler in November. My problem is the system is overheating.
The model is CL5648SB. The metal plate indicates it was manufactured in June 2001. It appears to have a huge firebox (it indicates the heat transfer area is 114) and a water capacity of 385 (I assume this is gallons). The solenoid opens the damper when the water temp hits somewhere in the 150s. That's about all I know about the machine. The former owner provided an owner's manual and showed me two valves to turn on for water flow when the machine was operating. I don't know how to set the water temperature on this model or if I even can.
I have been experiencing overheating; not always, but typically at night. I realize this isn't a pressurized system, but the amount of steam can be a bit alarming at times and occurs in temperatures below 185, often in the 170s. I could tell there wasn't a good seal on the door, so last week I replaced the rope seal. Additionally, I cleaned out the firebox and had the chimney swept. I had high hopes that my problems would be solved, but no. It also just started doing some smoke burps out of the damper door. The smoke temporarily stopped coming out of the chimney and "burped" out of the damper.
I've added water through the opening at the top of the roof. It appears to be at the right level per the tube by the door. Could air be creating the overheating situation? I've never bled the system from lack of knowledge how to do it. I am not very knowledgeable about plumbing issues in general.
Right now I'm running the thermostat in the house at a higher temperature to take some heat off the system. That definitely helps to some degree. But, we like having the temperature at 62 when sleeping and we've recently been running it at 70 to 72 because of the overheating. This is resulting in us being uncomfortable sleeping, but is also leading to increased electricity and wood usage.
Any thoughts or suggestions? I'm going to try to contact the closest dealer (in Montana). We aren't that remote, but service technicians are often difficult to find in our area. We have a solid journeyman plumber, but he is taking some time off to help his wife recuperate from a surgery. I'm looking for another plumber, but don't currently have one.
![[Hearth.com] Overheating and burping on Central Boiler [Hearth.com] Overheating and burping on Central Boiler](https://www.hearth.com/talk/data/attachments/309/309316-7530c30a90de25fc5a57584690ffc5ee.jpg?hash=osJlinjKqh)
![[Hearth.com] Overheating and burping on Central Boiler [Hearth.com] Overheating and burping on Central Boiler](https://www.hearth.com/talk/data/attachments/309/309738-ba23acbedcb39677f7d259b68fb99a44.jpg?hash=X1VGP9O3fW)
![[Hearth.com] Overheating and burping on Central Boiler [Hearth.com] Overheating and burping on Central Boiler](https://www.hearth.com/talk/data/attachments/309/309739-5ac18efc08f693e402b02876b0dc03f1.jpg?hash=UzeFCY40nr)
![[Hearth.com] Overheating and burping on Central Boiler [Hearth.com] Overheating and burping on Central Boiler](https://www.hearth.com/talk/data/attachments/309/309740-d308b99cde87326be77c8961db0dee79.jpg?hash=vOIPGJ64fV)
![[Hearth.com] Overheating and burping on Central Boiler [Hearth.com] Overheating and burping on Central Boiler](https://www.hearth.com/talk/data/attachments/309/309743-a7ae784f46ccff75c7a251f2292e5a53.jpg?hash=1RVAccFSqQ)
![[Hearth.com] Overheating and burping on Central Boiler [Hearth.com] Overheating and burping on Central Boiler](https://www.hearth.com/talk/data/attachments/309/309744-93250e850ccfdf2fa14c53b6a73cef24.jpg?hash=396mJtzeky)
![[Hearth.com] Overheating and burping on Central Boiler [Hearth.com] Overheating and burping on Central Boiler](https://www.hearth.com/talk/data/attachments/309/309745-e5fcc4a3a6ba0525fb429695944878ad.jpg?hash=qTVuWkUG2X)
