Hi all,
A question about my Green Mountain 40 and overheating. Let's say I reload my stove from coals (stove top around 350-375), keeping the air shut down all the way and reengaging the cat right after. If I add, say, three to four decent sized Ash splits, the stove usually eventually gets hot enough to where the cat temp starts approaching too hot and the surface temp gets past 600. It burns fairly slowly at first, but at a certain point, the fire gets pretty big and there's nothing I can do to turn it down aside from disengage the cat. Even with the air shut down, it rages a bit.
My burn times have naturally been quite low under these conditions (4 hours max, coals to coals), as it's quick-burning ash and there are only a few splits. I know that theoretically, I could increase burn time by really packing the firebox and using harder wood. But I'm terrified to do this given how hot it already gets. I understand, of course, that tightly packed wood will burn much more slowly and not all at once, but this seems impossible to achieve with the way my splits are cut and, as I said, I'm scared of trying this given the fear of overheating.
I don't seem to have any door leaks. The only slightly suspect thing is that the air control doesn't seem to affect the flames as much as it seems it should, yet I can't see how it would be damaged or disconnected or anything. But it's almost as if there's a governor of sorts on it.
Any thoughts on this? I'd really love to get my burn times up, but I also don't want a meltdown.
Robert
Robert
