Hi folks, This is my second year burning with my Harman P43. I'm having a issue with a high flame, and after 5-6 hours of burning a black/ sooted up glass. I'm an automotive mechanic by trade, diagnosing and complicated disassembly/reassembly are a part of my everyday life, But I am new to pellet stoves and stumped here. I've had a "pro" take a look at my stove. He stated that it was my air inlet ( a 3 inch fresh air hose ). He stated that he's never seen one installed on a Canadian stove and its only code in the US. I've since completely disconnected the hose at the back of my P43 stove. Same issue. ( Thanks for the $200 bill). The flame looks very high, and does not seem strong to me. I believe I'm looking at a rich running stove. Here is some photos of the flame running on 4.
Here is what I have done so far:
- Clean out Exhaust pipe, exhaust pipe T and insured no blockages
- Cleaned outside air pipe and insured no blockages
- Cleaned out: Full stove, burn box, all holes in burn box, under burn box, ignitor area, exhaust fan and exhaust fan passage, Cleaned ESP probe, Cleaned out Pellet Metering Slide Plate ( I followed the harman P43 owners manual and have done the full yearly service)
- Inspected Seals on the hopper lid, Glass door and lower door. All look to be O.K. (no signs of a vacuum leak from these seals)
- Replaced the ESP with new OEM Harman sensor
- Ran stove on test mode, Inspected flap on inlet air. It moves freely. Both Fans run O.K. Still re-cleaned both fans and blades once again.
- Changed between 3 brands of pellets
- Ran stove with outside air off and on. No change.
I get no fault codes, But after about 5-6 hours of burning the glass is completely black. The flame is very high on every setting. Am I missing something obvious? Any help would be greatly appreciated.
