Today I picked up an old Pacific Energy Super 27, along with a bunch of pipe and damper, for $200. This summer I will be putting it in my steel pole barn workshop. If I cut out part of a wall purlin and box it in like I would a window, I'll have about a 4 ft square area free of combustibles to pass the pipe thru, then run the pipe up the side of the building with sturdy standoffs. I'd also like to utilize the outside air kit. I've been using a diesel fueled torpedo heater, but $15 of diesel fuel every day or two adds up fast. I own 5 acres of hardwoods, so might as well utilize that. Heck, even if I bought the wood it'd be cheaper.
The only issue with the stove is the previous owner cut a 6" or so hole in the baffle. He said the stove wasn't hot enough and he thought about cutting it even bigger. I think I realized why. He had the stove sitting on the ground (blocking the bottom air intake) with the rear knock out plate for air intake still intact. The stove couldn't breathe. When we tipped it up to get it in my trailer, he wondered what that hole was on the bottom. I did my homework and downloaded the manual first.
So I can get steel from work and I'd like to weld it back up. What's it like removing the baffle on these?
