I was struck this morning by the realization that there are several paradoxes and other apparent contradictions in wood burning. I came up with a few to share - I wonder what other ones I'm missing?
Dry wood burns longer than wet - May not be true for pre-EPA stoves, but if you don't get it then you haven't experienced it.
You have to get the firebox hotter at first to get a good long burn - it seems odd that starting off cooler wouldn't be better eh?
Less air will get your more heat - Another EPA stove deal I'm sure, but true anyway
A larger stove can get you more heat from the same wood - basically this argues for having the right size stove instead of pushing the limits of a smaller one. Early to be certain on this, but so far it appears this is indeed the case for me with the PH upgrade from the FV.
I had a couple more but forgot them... (seems to happen more the older I get - no surprise there). Anyone else think of any?
