I'm working on installing my wood stove insert into an existing masonry chimney. I cut the damper out and removed the plate yesterday and found a little bit of the parging on the smoke shelf. I have a small spot in the picture attached that is down to bare brick just below the clay tile in the smoke chamber.  My understanding is that I don't have to repair this as I'm going to be lining this with an insulated flexible liner.
My question is, should I? Are there any thoughts as to what might have caused this and should I expect that more of the parging will come off? I'm assuming water intrusion and time is the cause (built-in 1976).
I just replaced the cracked crown with a proper concrete cap with overhangs and have repointed the exterior. In a month I will waterproof all of the masonry but this should have been done by the previous owner a while ago.
Also how clean do I need to get the smoke chamber? Is it ok the way it is? It is super awkward to get up in there with a wire brush.
Thanks for any input!
![[Hearth.com] Parging repair [Hearth.com] Parging repair](https://www.hearth.com/talk/data/attachments/313/313838-9fceb508830d025d77ddba67da0293f9.jpg?hash=S5M1iNSH1P)
