PE Baffle removal
rbiebr
10
Pennsylvania
Still a newbie to the wood stove world. I have a PE NEO 1.6 INSERT LE. Per the instructions baffle removal should only be done if it is not possible to disconnect at the chimney connector pipe. I would like to check the liner to make sure I have clean burning. Per the instructions a vise grip and hammer is needed to remove the front two baffle tubes. (Not sure I like that method) The main baffle its self looks fairly easy but haven't tried it yet.
Anyone out there with this insert?
Do you clean/inspect chimney by removing baffle assembly or do you disconnect at chimney connector?
Just looks like it might be a pain to remove baffle/baffle tubes/Ceramic board.
Any suggestions will be appreciated
