PE Summit insert $$ing
mainstation
344
N.Ont.
I am looking at the PE Summit insert to replace my worn out R14. Couple of questions :
a) assuming CDN $ and U.S greenback are at par, What can I expect to pay for the Summit insert?
b) I know all inserts need the blower fan, but are these Summit inserts really the "workhorse BtU wise that I read/hear about, seriously?
Thanks in advance.
a) they were, but dollar is falling. Currently $1 US = .95 Cd. However, it shouldn't be that important if buying in Canada. Pacific Energy is a Canadian company.
b) Yes, they are excellent heaters that convect pretty well even without the blower running.
(broken link removed to http://www.chimneysweeponline.com/pacsumin.htm)
this might help even though it's not in Canada.
Thanks all,
Any current Summit insert owners want to chime in about heat output.?
Not an owner, but as a retailer that does not sell PE I find myself having PE envy quite often.
mainstation said:
Thanks all,
In summer it's going to be a little quiet here. Search on Hogwildz threads. He has a Summit insert. Also note that the Alderlea T6 is a Summit in a cast iron jacket.
BeGreen said:
mainstation said:
Thanks all,
You left out the part about the T6 not looking like a microwave built in the 1960s.
mainstation said:
... but are these Summit inserts really the "workhorse BtU wise that I read/hear about, seriously?
Thanks in advance.
Correct me if I am wrong, but the BTU calculations are not based on BTU's released into the room. ie a freestanding Summit will produce/release more heat into a home than a Summit insert recessed into a fireplace.
I have had a PE Summit Insert for four years. Sometimes I wish I had bought a huge 4 cubic foot plus catalytic Buck Insert. That's just because I live in a large, rather leaky, ranch house, and I burn wood that most people here wouldn't take if you gave it to them delivered, and stacked for free.
That said. The Summit is an easy to use work horse and yes it will put off crazy amounts of heat. I have put good wood in it a few times and wow!!! I burn slab wood that is mostly poplar and other softwoods. I get 8 hours with enough coals for an easy restart and I don't use my house furnace at all. I'm have a metal block off plate. This year, I'm going to add rock wool to the block off plate and around the inside of the fireplace. I know I'm loosing a lot of heat up the chimney. Take that into account when you buy. Chimney Sweep Online rates the Summit stove and Summit insert at 48,392 btu over an eight hour burn. The stove is going to put all of that heat into the room. The insert won't, so install it properly.
I don't have experience with any other stoves, so I can't compare it to them, but I sure can't see how any of them would be much better. Get what you want and be happy, just don't take the Summit off your list because you think it won't do the job. It will.
LOL, tell me you didn't chuckle to yourself a little bit when you typed that in...
cheeky.
Thanks in advance.
Go to the main page for hearth.com and read the stove reviews.. PE stoves rate very well from the majority that own them and it helped sway me to buy the T-5...
Ray
Thanks in advance.
Ray
Ratings are here:
https://www.hearth.com/ratings/search.php
Heats 2666 sf fairly open floor plan since installed in 2006.
