I will add some eye candy......this is mine where it sits in the shop I bought it from. I do not yet have it home and hooked up.
Very nice! Are you going to give it a fresh coat of Stove Bright High Temp paint to make it look brand spanking new?
Thanks by the way !
Does $850 seem like a good price ??
I'm very familiar with most other heating products( Plumbing and Heating) side business for around 10 years,and I'm not to concerned with electronics related issues, as my "full time" career is electronics repair and some engineering. BUT I'm quite ignorant to pellet stoves ! Although I have learned allot over the past few months of looking.......
Where is the pics
Remember to post some pictures
We love pics when your done...
When I was a kid we used a wood stove and I think I remember t using a magnetic thermometer on the pipe and keeping the pipe between X-Y temp,
with the pellet stove using and insulated or double wall pipe what should the outside temp be on it ?
We had our stove installed yesterday and there is a bit of a learning curve with damper settings, So I thought we could monitor the pipe temp to help with damper settings.
The best way to setup the damper setting on a wood pellet stove is by using an analog magnehelic guage or a newer digital manometer to adjust the draft properly for the stove.
magnehelic guage
http://www.davis.com/Product/Dwyer_...rred_id=3388&gclid=CNXboLbCybwCFcdQOgodQjwADw
You can also adjust it by looking at the flame.
Yeah, Ive been looking at the flame until my eyes hurt and it all looks the same.............unless the damper is completely closed or completely open. I'v only ever really seen brand new Harmans burn in a show room setting and there flame seems straight and almost uniform, mine is anything but !
I don't follow the logic behind the gauge you posted, It seems to be designed to mount via "saddle vale" to small diameter pipe ?? Seems like it would be easier to spend $20 on a magnetic thermometer ???
interesting......not being able to run on "1" is an issue for me as-well.
! Please replace it with metal. NORMALLY it pulls air in so that's not a problem, but if power goes out, the hot air from the burn chamber will go back out the OAK and could cause a fire! Read the manual.We use essential cookies to make this site work, and optional cookies to enhance your experience.
