Pellet stove burn pot
Check in on the "pellet mill" forum..
Make of Stove ?
Whitfield advantage plus, I figured it out the damper rod is missing so moved the plate manually gave it more air now works perfect
My brickwell pellet stove p2000fs had that problem.It wss running me up a wall.Where the burnpot slips onto the air intake pipe was wore down.Put a piece of aluminun tape around the pipe.Put the burn pot back on.Case closed.Oelkets jumping out of the grate.I guess 14 years wore either the pipe or the outer grate down.
