I've been looking at getting a pellet stove to supplement my oil heat system and have come up with 3 potential installations/options:
1) Direct exhaust vent through exterior wall. I'd rather have the pellet stove more centralized, but it looks like direct venting is the easiest installation. However, I have wood siding, and am concerned that it would be stained with soot. Is this a common problem?
2) Run exhaust vent up through roof. I would like it located centrally on my 1st floor, and could run an exhaust vent through the ceiling, but it would likely have to go through a closet in the 2nd floor, and then out the roof. I'm not sure if it is safe/legal/etc to run the double-walled metal exhaust vent like this. Is this feasible?
3) Get a fireplace insert. I have a 1st floor fireplace that currently has a propane insert which I very rarely use. It already has a vent setup for the propane insert. Could I simply remove the propane insert and hookup the existing vent to a pellet stove?
Thank you in advance for your feedback
. Most efficient sounds like pulling a liner and replacing the propane insert.![[Hearth.com] Pellet stove chimney/type installation questions [Hearth.com] Pellet stove chimney/type installation questions](https://www.hearth.com/talk/data/attachments/75/75992-1d0e4e5b2757f467feb44e35ae8287c4.jpg?hash=AeG0wFrbJ9)
