Pellet stove install to oil chimney
Curiousstoveguy
3
Milford pa
Greetings all,
I am planning on installing my second pellet stove, but to my oil furnace chimney. The chimney opens to the furnace, so I would use a reducer to fit the pellet stove pipes. The chimney also has an ash door, easy access to clean ash.
However, do I need to install a chimney liner?
The chimney is clean, and used just a few months ago with the oil furnace, which I will have removed soon.
any advice?
thanks,
erik
Welcome to the forum
We could use a little more info
Type of chimney?
What size of the chimney?
length of the chimney?
Reactions: Mt Bob
Type of chimney?
Thanks for replying.
It was used for an oil burning furnace.
Length is approx 25ft. Type, I do not know. I attached pics.
[Hearth.com] Pellet stove install to oil chimney [Hearth.com] Pellet stove install to oil chimney [Hearth.com] Pellet stove install to oil chimney
Looks like an 8 in. square flue pipe in a block chase.
It has a cleanout ( bonus) Others will weigh in
maybe draft problems but I would try a reducer
from the round pipe to the pellet stove vent pipe.
I use a 6-inch class A chimney 20 feet long. It has
worked for me for the last 22 years.
Check the stove manual
Thanks! 😎
I also asked a friend of mine regarding this, and he said similar to what you have said.
