will711
Is it possible that when hubby vacuumed out the fines box that the fines deflector part # 10 in my manual is not seated properly ?
I appreciate you taking the time to explain all this. We just cleaned the fines box again and tapped around and played with the auger and now it's back to not working at all again. Also the slide plate from hopper came out and don't know if we will get that back in the right way. These stoves save money if they work well all the time but if they don't and you aren't mechanical and technical it's a huge PIA. I feel we maintain ours well and it was expensive and we didn't get what we paid for. Funny thing...we never heard of a pellet stove until we found out a cousin had one. He bought an old used englander that originally brand new came from lowes and he has never put a dime in it.My newer stove does the same thing occasionally and its FRICKEN IRRITATING! My dealer suggested removing the deflector to see if that will help. He blames it on the newer style MUCH smaller fines box. My older stove has never made that noise.
Haven't removed the deflector yet but what ALWAYS works for me is to get all the pellets out of the system and re vacuum the fines box. Place the cover back on but don't secure it. Put it in test mode, open the hopper and immediately push the safety switch down. Take the backside of a large-ish screwdriver and bang around on the slide plate and the hopper in that immediate area. Next, get under there and tap around on the components inside the fines box. Secure the cover. Now, get the slide plate actuator bearing off the arm thing. Take the blade of your screwdriver and lightly tap the tip of the arm. This will likely open the slide plate. Put in in test mode again and get the bearing back off the arm and repeat the tapping.
This works EVERY time I have the clunking....which is every ton or so, the interval recommend by Harman, even though the fines box is at most, 1/6 full. Like I said, my dealer seems to think the deflector is the issue but removing that looks like a PITA.
Anyway, give the tapping method a shot. Be thorough and it should dislodge whatever is causing the binding.
If you continue to clean that stove every 7-10 days, you will, in time, gain to hate that stove. Let it run for 30 days or more. I know it is hard to do but, try it. You will enjoy it more. DON"T TOUCH IT.Cleaned it today as I do every 7-10 days and it wont feed pellets. There are no blinking error lights. The combustion blower comes and and then nothing happens. What could have happen when I cleaned it?
???If you continue to clean that stove every 7-10 days, you will, in time, gain to hate that stove. Let it run for 30 days or more. I know it is hard to do but, try it. You will enjoy it more. DON"T TOUCH IT.
There is no need to clean a free standing stove every 7- 10 days. Let the stove burn and enjoy it. If I had to clean something every 7 days, I would hate it.
>I hope those plastic peices arent the fan blades for the auger motor. While this is my first post on this thread i will admit to be watching the conversation. At the beginning of this my immediate thought was that there is a vacuum leak somewhere and i still think that. It has been stated that it fails the dollar bill test and that shoud be fixed before anything else is done.
I'm usually pretty good at helping fellow Harman owners out here as well. I didn't have anything new to offer and I sensed your frustration. Having said that, you and your husband now know more about that stove than you'd probably care to admit. That Harman will give you many good years of service and as it turns out it wasn't a Harman problem. Bad pellets...happens more often than you'd think. Hang in there and enjoy the rest of the heating season.Well...my husband is a carpenter turned businessman, not mechanical or technical but he is a beast. He was done with the stove yesterday and although frugal he is not he decided no $100 service call. He unhooked the stove and with a dolly got it out to the detached garage by himself. My son and husband and I got it up in the truck this morning and he drove it to the dealer. Another plastic piece came out in the burn pot so the dealer determined the 4 plastic pieces came from our pellets and thats why it wouldn't work. Then when it did work but the auger was clunking, it was because my husband didn't have the slide plate from hopper in correctly he took that out when fiddling around trying to see what the problem was. Took the dealer 10 minutes to figure this out and plug it in and it was running fine. A day in the life of a pellet stove owner. I will say with 7 degree temperature we missed the stove. We were all cold last night and this morning. Furnace just wasn't keeping up although I'm sure it's guzzling propane. I just want to say thanks again for all the help. Pellet stoves aren't for everyone. We probably weren't good candidates for one and if it wasn't for you all and the patience and kindess with helping each other we would have put alot more money in it already with more service calls.
P.s. Boosted3g we will be replacing the gasket soon.
