I am close to the first ton mark on my stove and figured I would throw up a quick review so far. I already went into why I choose this stove so now it is time to dissect it a little. I don't see a lot of info on these stoves so figure I would throw some out there.
Overall I have been very happy with it. I heat an 1800 sq ft 2 story home with it. It was built in 1900, has pretty good insulation and most of the windows are newer. With the stove heating the room it is in to about 79-80 it keeps the entire house at about 69-72. I would not mind keeping it a little cooler but the wife likes it warmer. It has had no problem keeping up on the colder days. Since I have had it we have had lows of -20+ a few times and highs in the negative single digits and it has kept up just fine. It has 4 settings for the auger speed. It only gets put on 4 at start up and maybe an hour here and there when it is really cold and then goes back to 3. The wife has been through 2 house fires in her life so is still a little leery about it running when we sleep so it gets shutdown when she goes to bed. About 1:30 a.m. and gets fired up when I go to work about 4:30 a.m. So it runs about 21 hours a day. I clean it on Wednesdays and Sundays. Although I could easily clean it once a week or less but figure I can keep it more efficient if I clean it more often. Also I am burning Indeck pellets which I really like but do kick out some ash. It never needs to be scraped. The 2 corners of the burn pot get a little ash in them but that is about it. I usually just hit that quick in the morning with my cleaning paint brush and it is all clean. This is a no thrills machine. Everything needs to be done manually but once I got everything setup good I touch nothing other then the auger speed. I keep the convection fan wide open at all times. You can hook a thermostat up to it though and I think I will in the future. It has done nothing weird and has not had an issues to date. It does have a few cons though. I would prefer it to be a little quieter. It isn't super loud and it is basically background noise but it is about as loud as a box fan. Also it has a scraper for the heat tubes built in. Just pull it and it knocks the ash off. When it knocks the ash off though it drops it all in the burn pot and covers the igniter. Also not a big deal the vacuum sucks it out easy enough or the pot comes out easy for the brush to clean it off. The hopper is suppose to hold 120 lbs but actually only holds about 100 but again not a big issue. I probably average about 60 lbs a day so far. So far I would highly recommend this stove but I haven't had it that long yet so we shall see what happens in the future.
