Morning everyone,
I thought I would post a few of my thoughts today about my stove.
I bought a PelPro PP130 and installed it back in early November (started burning Nov. 22nd). The only issue was that the control knob was defective, so I called PelPro and they sent me one right away. After I installed the knew control knob, the stove has been running great. I expected to supplement my oil heat with the pellet stove, but actually the oil furnace hasn't kicked on once since I started burning pellets! I have about a 2000 sq. ft. house and the heat travels throughout most of it. Some of the rooms further away from the stove are a little chillier, but that's not an issue. Back when I was running just oil heat, my room with the thermostat was always set to 62 degrees. Which means the further rooms were about 56 degrees. With the pellet stove, the room with the thermostat is 76 degrees and the further rooms are 68ish. With the cost of oil versus the cost of pellets, we will have already paid off the stove this year!
My only problem is finding fuel. Since I bought the stove just before the winter season, its hard to find pellets that are in stock. And when I do find them, they are either expensive or not so great of pellets.
Pellets Burned so far:
25 bags - Natures Own
75 bags - Green Supreme
So far, Natures Own is my favorite of the two. At its hottest, my thermostat got to 94. The heat output is really hot. The burn rate is decent but I have to clean the ash out every day. The burn pot has somewhat of a hard ash, but nothing that I couldn't break up easily.
As for the Green Supreme, the only reason I have burned more bags is because that was the only fuel I could find at the time. At its hottest, my thermostat got to 92. Although that is close to the 94 from the Natures Own, the heat is only medium. I can keep my hand right in front of the blower burning the Green Supreme, but with the Natures Own, I can only hold my hand by the blower for a short time. The burn rate seems a little faster than the Natures Own, but then again I only had 25 bags of the Natures Own and the outside temperature wasn't as cold as it is now. The Green Supreme creates lots of ash! I clean my burn pot and ash chambers every day, more so than the Natures Own. I should also mention that the Green Supreme tends to blacken the glass easier than the Natures Own, but that's probably because they don't burn as hot. This really isn't an issue since I clean my glass every day as well.
Anyways, that was my quick wrap up of my first couple months as a pellet stove owner. If any of you have suggestions on pellets to look for in the Rochester, NY area, please feel free to comment. I plan on purchasing a few tons in the spring when the prices are lower. It would be nice if I can find a pellet that creates less ash. I have 3 bags left of the Green Supreme, so later today I will be picking up 10 bags of Barefoot since there is a limit on how much each customer can buy. According to reviews, it seems like barefoot might be a small step up from Green Supreme. Time will tell.
Have a great day everyone. And keep warm!
-theRog
-theRog
