i'm planning to do a full fireplace replacement (demo down to the studs, have a certified installer put in the new heat n glo northstar).
i'm curious about permits. i know you're supposed to get one per my local codes ((broken link removed to http://your.kingcounty.gov/ddes/forms/b-appaff-resmech.pdf) -- $205), but i question if it's worth it.
i read these two threads:
https://www.hearth.com/talk/threads/replacing-wood-stove-do-i-need-a-permit.63246/
https://www.hearth.com/talk/threads/what-home-repair-warrants-a-permit.69/
... and it seems like it's hit or miss on the quality of an inspector you'll get.
i'm generally handy (a structural engineer, so detail-oriented), but fireplaces are a bit new to me. i kind of want a second set of eyes on this to make sure the installer does it right. i am also concerned with regards to insurance in the rare event an improper install resulted in a house fire.
my conflict comes with other house projects i'm working on (including some structural mods that i engineered). i don't like the idea of a mechanical inspector coming out to see the fireplace and then see that i'm working on some walls without a building permit. however, i can delay this project 'til after the fireplace (inconvenient, but doable). i am just curious if the local mechanical inspector will be worth a darn or provide a benefit in some other form.
thoughts?
thoughts?
