We bought a 20-year-old home with a brick fireplace a few months ago. The fireplace is in the center of the house, brick, and has a terra cotta liner. We didn't notice any fireplace odors when we looked at the house (it was snowing--no AC turned on).
Fast forward to moving in in June, and the entire living room smelled like a BBQ pit. We called a certified chimney sweep who thoroughly cleaned the chimney and firebox, and inspected the chimney with a camera. He said it was filthy--an inch and a half of creosote had built up. He also placed new glass doors in the opening.
The next day, the smell came back. I read several threads on here about the AC pulling air from the chimney. Sweep temporarily capped the top of the chimney with sheet metal and caulk because we don't plan on using it, but future owners may. That should prevent air being pulled in.
We still had the smell. My husband put in foam rubber below the closed flue, at the recommendation of the chimney sweep.
Guess what! Still stinks. HVAC company installed outdoor air vent from roof to HVAC unit.
Still have the smell in the afternoons. Chimney sweep came back and put a fan on the top of the chimney for 3 days to pull air out. Finally, no smell!
So, he tells us our options are $3k plus fan installed on top of chimney (plus electrician's fee), chemical treatments to chimney at $1100 a piece (it may take 3 times) to remove baked in creosote, or sheet metal and caulk the opening of the fireplace and hide with screen to completely seal off fireplace. I really like the doors we had put on, but the way it mounts would mean losing them if we go the sheet metal route. This has already cost over $1k and we really, REALLY don't want to spend $3k+ on a fan. So...any other ideas?
