Anyone else having failures?
I had this one burst last Friday. Luckily I was home and heard it... 1" main supply line to my manabloc. The 'brass' is corroding and is very brittle.
There were two other 90's. One twisted apart when I touched it. The other looked brand new, but I cut it out anyways. There was corrosion on the inside of the fitting.
probably 10 or so. Starts out as a very slow weeping leak that causes that green corrosion. Then a slight drip. I've had two burst that were in areas that I didn't notice the corrosion. It's not the crush ring failing. Always the fitting.
