Just splitting to dry, unfortunately. It has sat for quite some time, but was up off the ground, but not covered. Will it get punky just from being in round form too long and uncovered?Are you just splitting this to dry or is it ready to burn? If you're just splitting it up I don't know if I'd give it a prime spot in my stacks, if its dried already you won't hurt anything running it through the stove. Maybe some is not so bad?
Sorry, I meant is that why it is punky to the degree that it is now? I have quite a few rounds of ash and this oak and the oak is punky whereas the ash is still in great shape. I thought the oak would actually last longer in round form than the ash..guess I was wrong.Could, but if you want it just keep it well covered. It'll burn.
Sent from my VS995 using Tapatalk
I'm a big fan of ash for it's quick seasoning, easy splitting and decent heat output. It has to be my favorite all-around wood to burn.For me, ash is the easiest wood to season. The only thing the splits have ever done is dry -- they never get bugs, fungus, anything.
Oak is not quite as easy, but being hard, that helps. I keep track of any oak logs that might get funky, and usually split everything the first year.
Apparently we have found "the weakest link" when it comes to the Oak familyInteresting. I have 2 pallets of 3 yr old Pin O. That was cut green. Split and stacked right away. Now it looks like yours on a fresh split? Some is still beyond my meter limit for moisture! Some checks under 20. Rather disappointed. Apparently needed more wind/sun.
