Yes Henfruit, as a reseller of Slovakian-made Vigas boilers, what information are you privy to?mikefrommaine said:henfruit said:There is along story about all the boiler makers from poland and slovakia that is not known by this fourm.
Do tell.
Do tell.
I appreciate you showing me your system Patrick, but you never told me the story. In fact, I'm fairly certain that you never even mentioned Poland or Slovakia. What have the Slovakians done to produce the "Rolls Royce" of boilers?henfruit said:Nice wood shed peter,I think i told you the story.Pete Schiller said:Yes Henfruit, as a reseller of Slovakian-made Vigas boilers, what information are you privy to?mikefrommaine said:Do tell.henfruit said:There is along story about all the boiler makers from poland and slovakia that is not known by this fourm.
Effecta Boiler User said:As a previous EKO 40 owner/operator (for 3 years) I can tell you that the effecta lambda 35 I now own/operate (this is my 2nd year of operation) is much easier to start fires in, requires much less attention once the burn is going (due to the Lambda sensor and individual stepper motor control), consumes less wood and produces less emissions in addition to looking very "sexy" (OK, if not sexy I must say it does look very nice).
Effecta has been using the Lambda sensor/stepper motor system for 7 years and thus has a very good history with it. The company has been producing boilers in Sweden for almost 30 years and also produces pellet boilers and solar collector systems along with buffer tanks (this fact should combat any concerns/comments about being a new prodcut to the market). The boiler also is capable of running without the Lambda sensor input if the sensor were to fail (a few simple key strokes on the control panel turns the Lambda sensor ciurcuit off).
Regarding pressurized storage, it is much simplier and in my opinion more efficient since it does not require a heat exchanger. Once the oxygen in the boiler/tank system has been "killed" it's very difficult to have corrosion occuring without oxygen (much like it is impossile to have combustion occur without oxygen). Not to mention, if you have propane tanks availabe locally it is very inexpensive to create.
I would think twice about spending the extra money on a variable speed circ. pump for the boiler portion/circuit which heats up the water batteries (storage tanks) becuase it only runs for 5-6 hours per day when heating up the tanks. At a consumption of 80 watts (with pump on high speed) thats approx. 400-500 watts per 5-6 hour burn cycle. In my area I'm paying about 11-12 cents per 1,000 watts and thus that means it takes little more than a nickle to operate the pump on my laddomat 21-60 loading valve for one complete burn cycle. However, I would seriously consider these pumps for the circuit which takes water from the watter batteries to the house as it will operate much more often.
My system is a very simple system. I pump hot water from the effecta lambda 35 boiler to the top of the storage tanks with one circ pump (laddomat 21-60 loading valve) and then pump water for the top of the same tanks to my residential heating system which consists of a combination of radiant floor heat and baseboard. I use an Azel Technologies switching relay to control the different zones in my house and the system works beautiful!
I hope this helps you in making your final decission as to boiler type/brand and system design/construction.
PS - I have included a photo of my effecta lambda 35 boiler and 2 x 500 stacked propane tanks storage (underneath the blue foam box) for your review (the front cover on the effecta lambda boiler is removed in this photo so that the individual stepper motor draft controls can be seen).
Thanks,
Brian
!I don't think the jury is back on that Stee. I thought the same thing you did. The website shows servo control of the secondary through Lambda & doesn't mention how the primary is controlled. If you know exactly how this boilers air is controlled would you please post? I've asked this question of others with no takers. Thanks, Randystee6043 said:I may be called a doubter but I have yet to be convinced that "lambda" control that cannot independantly control primary and secondary air mix is any more effective than altering fan speed. In my humble opinion the Vigas cannot be compared to a Froiling. They are not the same class of boiler.
I bet the Vigas is easier to start than an EKO. But I'd be shocked if it was measurably more efficient than Tarm/Bio/Eko in an apples to apples comparison. My opinion only.
I wouldn't agonize long, deciding between an EKO or an Effecta with Lambda. The OP is worried about a probe failing, I guess thats why I would carry a spare. A lightening strike will take out either boiler so the controller is a non issue to me./// Are you stocking spares for these boilers Brian? I like the fact that secondary air is fed in through the entire nozzle length so unburned gas don't escape. I'm probably overly concerned with emissions as was pointed out to me. Theres worse than being an environmentalist I guess, RandyEffecta Boiler User said:Yes, you are correct!
I compare the effecta and Froling lambda control and operating systems to that of an oxygen acetylene torch (they maintain the correct ratio of primary/secondary inlet air to create a purple/blue flame and the "perfect burn" at all times throughout he entire 5 hour burn cycle). If the oxygen acetalyle torch is adjusted for too much acetylene it has a yellow flame and emits black soot. If the torch is adjusted for oxygen only it will not have a flame. However, once the ratio of oxygen and acetylene is perfected, a nice blue/pruple flame will cut through a 1/2" plate of steel!
When the effecta lambda 35 boiler is first started up it is cold and does not have a complete bed of hot coals. Thus, the lambda control system will default to a 70% primary / 30% secondary draft opening scenario.
Once the smoke/chimney temperature (which is displayed on the control panel) hits 101C the lambda control system then opens up the primary 100% and closes the secondary 100% so that a hot bed of coals is established as soon as possible.
From this point the boiler obliviously gets hotter and then the lambda control system closes the primary draft opening and opens the secondary draft opening in a effort to maintain the Target CO2 % setting.
This automatic opening and closing of the primary and secondary draft openings occurs throughout the entire 5 hour burn, thus ensuring maximum heat output, minimum wood consumption and minimum emissions.
Hope this helps!
Brian
huffdawg said:stee6043 said:I may be called a doubter but I have yet to be convinced that "lambda" control that cannot independantly control primary and secondary air mix is any more effective than altering fan speed. In my humble opinion the Vigas cannot be compared to a Froiling. They are not the same class of boiler.
I really cant imagine any boiler being easier to start than mine . takes 3 mins.
henfruit said:There is an other thing all you eko users should be aware of they are not ul tested.So if you have a fire and your insurance finds out i doubt that you will be covered for your loss.
Henfruit, Unless there are 2 independant servo flaps or at least one servo flap & control of fan speed you cannot adjust ratios in an optimal manner.. So far no one will step up to the plate here & clarify. So I'm just going to assume the ratio is not adjustable as the Froling & Effecta are. Maybe you can do some digging & get some good info Henfruit? Thanks, Randyhenfruit said:Stee,Tell me why the vigas is not in the same class as frohling?(not as pretty) Randy if you look at the cut away of the vigas the primary and secondary air are run by one servo motor with two shutter fan blades. Huff, That long with a full load of wood from torch to start up gasification under a minute.The controler on the Vigas is way advanced than all the boilers out there except the frohling and the effecta.There is an other thing all you eko users should be aware of they are not ul tested.So if you have a fire and your insurance finds out i doubt that you will be covered for your loss.
stee6043 said:huffdawg said:stee6043 said:I may be called a doubter but I have yet to be convinced that "lambda" control that cannot independantly control primary and secondary air mix is any more effective than altering fan speed. In my humble opinion the Vigas cannot be compared to a Froiling. They are not the same class of boiler.
It's the red solo cup. Takes 10 mins off start up, minimum.
Don L said:henfruit said:There is an other thing all you eko users should be aware of they are not ul tested.So if you have a fire and your insurance finds out i doubt that you will be covered for your loss.
This is taken from CozyHeat Website:
"The Orlan EKO is currently the most popular gasification wood boiler in America. This boiler has been our main-stay for over a decade. We have had almost no problems with this boiler in that many years that is certainly something to be proud of! Positive draft, easy cleaning handle on side (no need to shut down stove and manually clean), RK2001UA controller, modulating draft, direct communication with your oil or gas boiler, 2" supply and return ports with American threads. U.L., CSA, C.A., TUV approved."
Is this not true?
huffdawg said:Don L said:henfruit said:There is an other thing all you eko users should be aware of they are not ul tested.So if you have a fire and your insurance finds out i doubt that you will be covered for your loss.
Is this not true?
Don I see TUV stickied onto the back of the boiler but no CSA or UL.
Singed Eyebrows said:Henfruit, Unless there are 2 independant servo flaps or at least one servo flap & control of fan speed you cannot adjust ratios in an optimal manner.. So far no one will step up to the plate here & clarify. So I'm just going to assume the ratio is not adjustable as the Froling & Effecta are. Maybe you can do some digging & get some good info Henfruit? Thanks, Randyhenfruit said:Stee,Tell me why the vigas is not in the same class as frohling?(not as pretty) Randy if you look at the cut away of the vigas the primary and secondary air are run by one servo motor with two shutter fan blades. Huff, That long with a full load of wood from torch to start up gasification under a minute.The controler on the Vigas is way advanced than all the boilers out there except the frohling and the effecta.There is an other thing all you eko users should be aware of they are not ul tested.So if you have a fire and your insurance finds out i doubt that you will be covered for your loss.
