Where to start, where to start.. This could get LONG.  I made a post last year about this time, looking for advice on wood vs pellet, pros and cons of each.. Well, this past February we went 6 days without power after an ice storm, our only reliable heat source being a portable propane heater.. Not to mention the generator dying twice on me and basically being at my wits end and freezing for nearly a week.  Temps in the 40's and 50's. INSIDE. We had planned on installing a pellet stove but funds ran out and it never happened. After the week without power I want a wood stove.  I want reliable heat that doesn't rely on electricity if the s.h.t.f.
Anyway, same drafty 1500 sq ft farmhouse in a corn field in Michigan, new plan. I've done a little more work to the house as expected, just discovered that the previous owners installed a new laminate floor over one of the cold air returns, so that needs addressing yet.. One day at a time..
I've never bought or had a wood stove installed, I do know I won't be doing the install! But should I just go to a local stove and fireplace shop, take a look at my options and have them do the install? I'm just imagining needing to install some kind of hearth, saw some holes for the chimney and drop the pipes down etc but I know there's more to it than that.. Trying to stay within "code" or whatever I need to comply with for homeowners insurance, can I just buy a stove and have someone handy install as long as they follow clearances and hearth requirements? Do we need to pull permits or would the installer need to? Sorry to sound so clueless, I promise I know how to build a fire and no I'm not going to burn the house down!
Placement.. I know it's going to be in the main living/dining room on the 1st floor, but we have a couple options.. Or do we? NW corner of the room, middle of the North wall, or SE corner? There is an old chimney that once served the basement which would be accessible from the SE corner but I have no idea what condition it's in. Chimney once served a wood furnace and oil furnace.. Both long since gone and disconnected. Otherwise the chimney would need to either be externally mounted on the house, or extend up through the 2nd floor and roof.. Not sure if either of those are options, or which is the better option?
STOVE.. What kind/size of stove do I need? I know I don't want a catalytic style stove but one with secondary burn tubes, and I want a glass window to see the fire. Nothing too big, but I want to be able to properly heat the house.. 1500 sq ft, drafty, so say closer to 2000 sq ft? What kind of footprint/hearth footprint should I be planning for? I don't need a fancy ornate cast iron or soapstone stove, it's an old farmhouse. I don't want to spend a mint, but I want a decent stove that's not going to fall apart or burn the house down.. Again following whatever I need to to please insurance (state farm)
Wood? I have a covered, open ended steel barn out back I'm figuring on stacking wood in, and putting a firewood ring on the front porch.. Haul in only what we need for the stove as I DON'T want bugs in the house.. But how much wood should I plan on getting? How much should I pay for cut/split/dry wood? I do have a small wood pile of DRY old wood to get started, figure it might last a few days to a week. Definitely not enough but a starting point.
Anything else I'm missing?? We have heated with wood in the past, so we know how to build a fire/run a stove, but I'd appreciate any advice!
