I will have pictures later once the install is finished. about 2 weeks ago I filled boiler with well water. Tank to 47 degrees.in 3 hours and 40 minutes of firing I brought it up to 180.mind you I was sitting there making sure the fire box was completely full at all times. rockin and rollin is the term for doing that I think. Heater man concurs.
moisture content of wood 20%.I just fired up again the tank was a hundred two degrees in an hour it was 139 degrees.
will check in later phone is dying. This was done by voice to text. Hope it makes sense
