Hello all!
I know it has been discussed previously, probably ad nauseam. But no matter how much I read and research I can't quite decide how to handle my clearance to combustible with regards to the 1 inch air space. The manual for my stove, a Pleasant Hearth 1800, makes no mention of the air space, it just says I need 14 inches of clearance to combustibles. But the manual has also neglected to mention the recommended r-value for the floor covering, which I mentioned to the company and have also unfortunately been really disappointed in so far.... but more on that later....
Back to the issue, the stove needs 14 inches to combustibles, and I have up to 19 inches of clearance to work with on the back of the stove. This is a new room build and has 2x6 framing, with insulation but no wall covering. My plan is to install some durock cement board, one or two layers if needed, then screw and cement some limestone slabs to the studs, some of the slabs are up to about 2 inches thick. The limestone will be decoration, and since the stove will be 19 inches from combustibles I don't think it will be needed as a heat shield.
Do I need the 1 inch air space if it is not mentioned in the manual and I'm within the clearance to combustible to work with? The manual has proven to have discrepancies and I'm not sure I trust it, nor has the company been very helpful.
Thanks in advance for any help,
Larry
Larry
