Please help me understand new/hyperactive cats
Guess52
11
PA
Recently installed a blaze king princess insert. Overall we're very happy.
Burning ash that was standing dead for years and reads 14-20% moisture at room temp, fresh split, along grain. I have been reloading with the cat still active and running at highest thermostat setting until I have full flames and outside char on the logs. Typically this means I'm turning the air down when the cat probe reads at the very top of the active range.
After our initial small paint curing fires I was a somewhat alarmed to see the cat temp probe far exceed the active range (6 o'clock position). Calling BK, they told me not to be alarmed and just burn as needed for my heating needs, the cats start overactive and then calm down over time. That said, the manual also alludes to damaging the cat by overheating it...
With some colder nights I've been loading more fully and not turning the thermostat down as completely. This morning about 40 minutes after reload the cat thermostat had completed over a full 360 and made it back into the labeled inactive zone (8 o'clock) but was glowing cherry red and obviously cooking. Fan was on high, thermostat was at 25%.
1) when should I be concerned about cat temps causing damage?
2) I'm not really understanding the "hyper active" description on a chemistry / physics basis. My naive assumption would be that the cat temp is defined by the flux of unburnt wood gases passed through it and the rate at which it can transfer heat out to the stove/room. Unless it were to dramatically lose efficiency (and presumably increase emissions) what's going to keep it from overheating similarly after break-in if I'm putting the same amount of fuel through it?
Thanks so much.
Draft is 24' of pretty straight shot insulated chimney liner if that's relevant.
  • [Hearth.com] Please help me understand new/hyperactive cats
I know that it'll settle down. I'm hoping to understand what that means. Is is the case that it's no longer burning all the gases during peak off-gassing?
Likewise, the BK thermostat doesn't show temps but the manual states "
Extreme temperatures (above 1800°F, or
1000°C.) at combustor surface can cause the catalysts to peel. Over firing and flame impingement on the combustor are primary
causes."
If the BK probe anything like this condar cat stove probe (Pic attached), it suggests I'm well, well over 1800F by the time the needle gets to 6 o'clock let alone does a 360. I know there is a warranty but I'd still prefer not to need it.
causes."
Definitely normal concerns, it's possible it's not burning all gasses but likely is doing a good job. When do you close your damper? Sometimes waiting for the catalyst gauge to be in the active is too long. Most around here engage their bypass at 500-600 internal flue temp or when the fire is burning robustly. I have a hybrid stove and once I see my secondary burn system kick on I know I'm good to engage the Cat.
I'm typically reloading while the cat is still active. I close the bypass to engage the cat immediately after I close the stove door. I turn the thermostat/air down once I have char on all the wood. Timing depends on volume of ember bed and load.
Reactions: stoveliker
OP is asking an interesting physics/chemistry question and I'll try my best to answer in a way that makes some sense.
It is pretty intuitive that a brand new catalyst will have the most "active sites" of catalyst material where unburned organic material can bind and be oxidized at the highest possible rate in a confined volume which leads to a high temperature. After the catalyst is used for a while, some of the catalyst material becomes masked by contaminants such as ash. Also, the surface becomes annealed by the high temperature and loses surface area. Both of these will reduce the available active sites for the chemistry to occur.
Now, as to whether you lose efficiency after this initial degradation occurs, the short answer is no. BUT it's complicated. The high temperature of the catalyst during initial stages of the burn when you have the most organics offgassing (even after some catalyst degradation) is usually sufficient to promote secondary combustion of flue gas downstream of the catalytic element without directly requiring each molecule to interact with the catalyst. So although the catalyst efficiency itself is reduced, you will still get fairly complete secondary combustion and the heat will be distributed over a larger volume, leading to a lower measured cat temperature. At lower temperatures where the catalyst is the only driver of secondary combustion, there will also be a lower volume of organics passing through the catalyst so it will be able to keep up over a wide range of burn conditions.
Eventually, as the catalyst surface continues to degrade there will be more heat input required to sustain secondary combustion, and you'll see some incomplete secondary action at lower temps. That's when you'll see the dreaded smoke from the chimney and know it's time to clean or replace the catalyst.
Reactions: BKVP and Highbeam
I don’t think those cat probes are the most accurate instruments. An Auber thermocouple probe would be much more accurate imo.
Reactions: BKVP
I do think that the cat settling down is indicative of the cat doing less. (The cat temp is primarily originating in how much it combusts.)
So I do think that these initial burns will be the most clean exhaust that you can get.
Yet, there is nothing one can do about this.I think these cats are made such that they can't sustain their initial combustion efficiency/heat production (they degrade, aka "settle down") - but are able to maintain a sufficient combustion efficiency over the long term.
(I do think that the production of the cat, its wash coating surface area and distribution of active metals, is unlikely to be cheaper if they would be produced at a lower "quality point", i.e. at the lower, more steady state efficiency they reach when they have degraded a bit.)
To me this asks the question whether the EPA testing is done with this initial high efficiency, or (also) later in the cat life. (I vaguely remember that some later datapoints are also involved, but I am not sure.)
I think the EPA tests require a stove be broke in for 50 hours before the test. What that entails I do t know.
50 hrs might not settle it down, at least completely so (in my case it took about a cord).
Reactions: Todd
I too recall that the testing is done with an "aged" catalyst.
As to the OP question, I think there is also a feedback loop. The extra hot cat produces an extra strong draft that sucks more air through the fixed minimum air orifice even when the thermostat is closed and feeds the primary fire extra air. When that cat is ripping hot, the stove is ripping hot too and I think the minimum output is a bit higher than it will be later in the cat's life.
As the cat settles down this whole feedback loop settles down so you can get longer, lower, burns while not missing much smoke.
Reading your post, I thought you were going to reach the opposite conclusion: an extra hot cat produces extra strong draft, which sucks more air into the firebox, which increases primary combustion and thus decreases cat-fuel.
Also, an observation from my stove: when the cat is so ripping hot, the stove does not (and often is not) need to be hot. Indeed, it's often the opposite; a mediocre output pile of glowing chunks and a bright yellow light from the cat.
Reactions: huauqui
In my experience the primary fire stays smoldering. No active flame when the fresh cat is overactive so the primary "fire" is not eating smoke. Since I almost always run a cat only fire, the cat is the source of heat and a ripping hot cat means higher output.
It's all academic, we don't have any control really.
ah. That's a difference; I regularly do have some flame (running the stove from the basement for a 1700+825 sqft home, I often run at the border of flame and no flame - seeing the Tstat open and close by the appearance of flames).
Academic is good :-)
I do think an even better explanation/illustration of this hyperactive cat issue (that pops up in *every* new BK user post here) might be useful in the manual. Even if only to avoid many questions sent to dealers or BK themselves.
THe many questions here suggest that many folks don't get it sufficiently from the manual. It'd be good to avoid initial misunderstanding, or worse frustration or fear. @BKVP
Reactions: Highbeam and BKVP
All wood heaters (ALL) now require conditioning (USE) prior to certification testing. This conditioning data is part of the test reports. Prior to 2015, ONLY cataltyic stoves had this requirement. Now ALL require conditioning.
BKVP
Reactions: Todd and stoveliker
When I first started out I had the same concerns. I eventually I discovered I could lower the temp on the cats thermometer by running my fan. I'm not sure that does anything constructive other than making me feel more comfortable about the situation. After repeated examinations of the cat after having had high temps like that and seeing that my ceramic cat had not cracked do to some thermal stress I eventually just accepted it as the way things were.
I do get however the idea that a strong draft, mixed with the right amount of fuel flowing through the cat, can create temps that exceed tolerances. @Guess52 did mention a 24 ft straight pipe. That's at least 8 ft more than mine. I'd have to think that his draft might be pretty strong and could be playing at least some factor in that thermometer wrapping around to 8 o'clock.
A strong draft will more likely decrease cat temps because the residence time of the gases is shorter and thus they have a lower probability to get combusted in the cat creating less heat.
Reactions: Warm Floor
If you are feeling better, great. However, air moving cross the top of the stove hits the bimetallic spring on the underside of the the cat therm and influences the reading you observe..
BKVP
Reactions: Highbeam
I'm no expert, so I'll defer to your wisdom @stoveliker. If you were to put this on a multiple-choice question in front of what I know I could see either answer as feasible. If contact with the combustor is what ignites the fuel, then I guess it's more likely that higher draft would cause more fuel to be missed? If the space in-between the walls of those cells is as hot as I think it might be when glowing, I'd also think even the fuel not touching the wall would just incinerate? My human mind can picture both scenarios.
I Alway's thought an overfired cat was caused by accelerated draft. If it's not from that, what is the cause of an overfired cat?
BKVP
Thanks for that clarification. I had a feeling it was the effect on the spring and not an effect of what's going on 3 or 4 inches below that spring.
overdraft has been seen to increase particulate emissions - i.e. less stuff is being combusted (into CO2).
And the heat of a cat is mostly generated by combustion in the cat, not by hot gases from the primary fire heating it up. Of course they do heat it up (that's how you get to the active range), and they do contribute. But if it's hotter than 1000 F, it's my estimation that most of that heat is generated in the cat.
Overdrafting can damage a cat, in particular when the overdraft sucks flames into the cat (flame impingement).
A cat that is too hot can get damaged, by having coatings spall off (delaminate). I think that's because the thermal expansion differences, which get worse when temperatures get higher, make things instable.
However, as manufacturers note, initial (too) high temps don't do much if any damage.
I don't know what the normal "conditioning time duration" is that is done before testing as bkvp mentions above, i.e. at what cat age continued exposure to (too) high temperature would be damaging. Of course this depends on wood species and burning type (high, or low and slow) too.
For me the cat settled down slowly - I think slower than for most from what I see on this forum.
It took about a cord of burning for me.
I would guesstimate that between a face cord (1/3 of a cord if you have 16" long splits) and a full cord, things should have reached steady state.
Over firing, thermal shock, impact from fuel or cleaning instruments are all contributors.
BKVP
Two thoughts..... yes, higher velocity through the catalyst would cause some smoke to be missed (less residence time) BUT that same overdraft causes more air to feed the fire which causes more smoke to be produced by the primary fire so even if more smoke makes it through the catalyst there is much more smoke being produced.
It's like when you roll open the secondaries on a 4 barrel carb, sure it's less efficient but still more power!
Whether more smoke is produced when more draft sucks more air into the primary fire, depends.
When running full black box mode (as highbeam), and the more air doesn't ignite primary flame, then yes.
Any other situation, more air will decrease smoke production imo.
Fascinating discussion. I'm one of those happy, but nervous new owners. On my Ashford 25 [8-10 burns so far; 15-20% mc Oak, longerish straight flue draft of 18-22 feet]. I notice that turning down the Tstat to lowest setting often bumps needle higher [1 o'clock position or 40-45 % into the red/active range on the gauge] and pushes higher heat out of the maxed fan [from 325F to 400F] .
I'm burning without a flue sensor in a tighter masonry/brick fireplace [just fits] and with blockoff plate.
The nervous point comes from the fact that Temp goes UP, even when thermostat setting is at LOWEST possible setting [cat is full glowing yellow, and primary flames are not extinguished.] Ergo, nothing in the manual to reduce temps at that point - even if I wanted to.
Q: Aside from the question of potential cat damage, safety. Should I be concerned about potential damage to or melting of flue pipe at the collar when the cat is "hyper active" ? How would I know and when or under what conditions I should be concerned?
Thanks!
