Hi all.  I am in the process of having a pole barn built on my recreational property to give me a place to spend the night when I am there for long weekends.  Previously I stayed in a travel trailer that I heated using a Big Buddy heater and a 20lb propane tank.  I kept the tank outside and ran a hose through one of the windows to connect to the heater and then also kept another window cracked for ventilation.
I am really unsure of the best way to heat the pole barn (it is 30x30 but I plan to block off probably half as a living space so the heated portion will only be about 500 sq. ft.). Originally I was thinking about a wood stove since I have pretty much an unlimited supply of trees but I think that the small space may not warrant a large heat source like a wood stove. So I have been thinking more about a direct vent or a vent free propane heater. From the limited knowledge that I have and little research that I have done it sounds like the vent free are the simplest and most efficient but I really worry about the safety. I will not have windows on the barn so it will not be well ventilated.
I am open to any and all opinions and ideas and look forward to hearing some thoughts. Thanks in advance.
