Finally got around to doing this once I had some vacation time.
Prep Work
1. Got the materials, all from Home Depot:
One package of Roxul Safe n' Sound, $42.00
One package containing three 5/8" wing nuts, $2.00
One 12" long piece of 5/8" threaded rod, $1.75.
One 36" long piece of 1/8" thick steel, 1" wide, $5.00
Two pieces sheet steel, 12" x 24", 16 gauge, $17.00
Two 5/8" nuts, already had those laying around.
2. Took off the front of the stove, then the surround. The front comes off easy, all I had to do was unscrew the ring on the end of the rod that moves the cat back and forth; then the whole face just pulls free. Next, two screws were removed that were keeping the surround attached to the stove body. Those came out, and the surround lifted right off. Then I took a picture of how the blower fan controls (built into the front) connected from the blower, disconnected them all, and removed the front and surround to another area.
3. Took a good look all around the stove, up inside the shelf and the chimney, got a feel for how the Roxul would go up, and where the support struts for the sheet steel would go. Took some pics. Cleaned out some masonry debris from the top of the shelf, which was there from when the masons demo'ed the top of the chimney last year and rebuilt it. Cleaned and vacuumed it all out.
4. Cut the threaded rod in half to make two pieces. Measure the damper opening and cut the steel bar to span it securely, making two 9.5" pieces. Drilled one 5/8" hole in the center of each support bar. Didn't have lock washers so I deformed the threads on one end of the rod pieces so the nuts wouldn't slip when I put them on the ends.
5. Spent a while measuring and cutting and shaping the sheet steel into two pieces which would snugly cover the opening. This took the most time and was the most effort. The liner goes from the stove up the chimney at a weird angle, so I had to shape a weird opening in one sheet, and have it overlap the other one. It's tight in the area where the stove is, and it was hard to get my arms up in there, and the pieces up in there as I was working on them.
6. Tightened the nuts onto one end of each rod, and slipped the rods into the holes in the struts. Then I found the best spots for the struts to span the damper opening, and marked those locations. I eased the sheet metal pieces up into place and checked where the rods would make contact, then drilled 5/8" holes in the sheets at those locations.
7. Opened up the Roxul to see what I was working with, see pictures. It comes in batts within that bale, it's not loose like cotton candy. More like layered cake. Folks on the web say you can cut it with a bread knife, but I just pulled hunks off by hand. it was slightly messy to work with, but not itchy. It tears apart easily, like huge slices of bread.
Installation
1. Stuffed around the liner as high as I could reach with Roxul, then packed it all the way down to the opening. This took a while, and I had to use chunks of varying size; big pieces for the beginning, smaller pieces at the end and behind the liner. The stuff is already compact and dense, so it doesn't wad up in the cavity the way that fiberglass or a cotton-candy-type material might. You really have to keep jamming it up in there, and it will keep falling down until it's packed tightly, and you have the plate in place.
2. Once one side was stuffed full, I put the support strut in place across the damper opening, then slid/pushed the sheet steel almost into place. I guided the dangling rod through the hole in the sheet steel, and got the wing nut on the end of the rod. Get the wing nut on fast, because holding everything in place was tricky. Then I pushed the sheet steel into final position, and fastened the wing nut all the way up against it, securing it in place.
3. Did the same thing for the next side. It went easier the second time, and the pieces fit very well over each other, and across the opening. The Roxul stayed in place pretty well on it's own, but the sheet steel was needed for sure, because I could see that the Roxul could shift and fall down over time. The sheet steel kept it up there quite securely once it was fastened to the struts with the wing nuts.
Pictures
Pictures show the stove with the front and the surround off; the left side of the opening; the right side of the opening; the Roxul bale, one of the sheet steel pieces, and one rod/strut assembly; what the Roxul looks like inside the package; the packing of the left side with Roxul; the left side packed full with the strut/rod in place; and the left side with the steel sheet screwed into place.
![[Hearth.com] Poor man's block off plate installed [Hearth.com] Poor man's block off plate installed](https://www.hearth.com/talk/data/attachments/170/170243-212ce9038ac663f42efb0df73765fc7e.jpg?hash=pM4b1xujn_)
RESULTS
So far I was only able to have one fire to test things out, and it was 65 degrees outside on Christmas day, so I don't think it's really a true result. at least I hope not, because after all this, it didn't seem like the house got any warmer than usual! With the temp set at 62, the temp in the house got up to 71 with a small fan running a convection current, which is only 2 degrees warmer than usual. I'll have more data to report when we're back in town in a couple days, and it gets back down to the 40's and 30's like it should be.
Prep Work
Installation
Pictures
![[Hearth.com] Poor man's block off plate installed [Hearth.com] Poor man's block off plate installed](https://www.hearth.com/talk/data/attachments/170/170237-64b4ae12aa4e629430d884d6fc04fb73.jpg?hash=tuDjsoGUWn)
![[Hearth.com] Poor man's block off plate installed [Hearth.com] Poor man's block off plate installed](https://www.hearth.com/talk/data/attachments/170/170238-c9e393ad9a02a6187721615efd3611cf.jpg?hash=8E5GRl6J8x)
![[Hearth.com] Poor man's block off plate installed [Hearth.com] Poor man's block off plate installed](https://www.hearth.com/talk/data/attachments/170/170239-66738650a1cad63d7495390d5116bc02.jpg?hash=P0xJof9qnY)
![[Hearth.com] Poor man's block off plate installed [Hearth.com] Poor man's block off plate installed](https://www.hearth.com/talk/data/attachments/170/170240-a563b84f8a482157c4a21bd959608501.jpg?hash=hRMaiFZ5Tz)
![[Hearth.com] Poor man's block off plate installed [Hearth.com] Poor man's block off plate installed](https://www.hearth.com/talk/data/attachments/170/170241-435045f82172fa1e3c37b14c285eccb7.jpg?hash=8e_1MgSFqf)
![[Hearth.com] Poor man's block off plate installed [Hearth.com] Poor man's block off plate installed](https://www.hearth.com/talk/data/attachments/170/170242-940dcd4af0d5fe75ad90ddfb28a3978e.jpg?hash=3sNwk0ZKFc)
![[Hearth.com] Poor man's block off plate installed [Hearth.com] Poor man's block off plate installed](https://www.hearth.com/talk/data/attachments/170/170244-7620747d46d588114bdaab2159161835.jpg?hash=R-P2vgV6f4)
RESULTS
