I am a first time home owner AND a first time fireplace owner. My typical NJ Bi-level style home has a masonry fireplace on the first floor. I have a spring loaded, gasket sealed top damper installed, which claims to be airtight and I do not see any sunlight coming through when it is closed. I have overlay style glass doors on the front of the opening, which are not airtight. Since moving in I have attempted to burn 2 "fires" (using a small 2 pound duraflame log, dont laugh!). The situation I am experiencing is that after the fire has gone out and I have waited for the afterburn "coals" to have died out and cooled off, I proceed to clean up the "ashes" and dispose of them. Then I proceed to close the damper, approx an hour after my little fire has gone out. About 30 mins after I close the damper and the glass doors the entire first floor smells like smoke. 30 mins later the enitre second floor smells as well. The smell seems to first encompass the fireplace room, them proceeds to the hallway and up the stairs to the second floor and then to the back of the second floor hallway where it so happens that the attic door is located on the ceiling. It is important to note that when i re-open the damper the smell seems to lessen significantly.
I have read through many many posts on this site and my best guess is that I have a "negative pressure airflow" problem, possible caused by a drafty attic. I hesitate to mention this guess since i don't want to influence any solutions you may post.
Please help. Thanks in advance to your assistance.
