I have a blaze king princess pe32 that I purchased last year with about 8-9 feet of double wall pipe and 2 45s inside the house with 12 feet of class A pipe on the outside. I cleaned the chimney two weeks ago using my soot eater through the bypass. I got maybe a quart or so out of the chimney after burning 2-3 cords last year.
Anyways I was burning for only 2 weeks since I cleaned the chimney, with just a single fire at night. So the other day I went to start a fire and had the bypass open, I usually set a timer for the 10 or so minutes to check it while it reaches operating temp. My timer went off and as I was heading to the stove I noticed a hot smell and heard some popping in the pipe. I immediately closed the bypass, which the stove was up to temp and then turned the thermostat all the way down as I noticed something wasn’t right. My double wall pipe near the elbows was either burning off dust or paint as there was smoke coming off the pipe . The pipe was approx 450 degrees exterior from my IR thermometer. I got onto the roof and did not see any flames exiting the chimney.
What I am unsure about is how exactly my pipe could have gotten that bad in just two weeks. Unless my cat is somewhat plugged, I did not remove it. It routinely glows orange while in use, but I have seen some smoke outside when burning.
My wood is the same as I burned last year, not covered the best as wind had blown the tarp off, but typically low 20s for moisture content. Anybody have any ideas how that could happen so fast?
