Is there any Practical Advantage to a Fresh Air Intake for Pellet Stoves?
I understand that Fire loves cold dense air... and there is no advantage to burning warm room air and then shooting it up and out of the chimney.
But is there any one out there who can say that burning air fed from the outside has saved bags of pellets over the season?
The Reason why I ask is that my Castile Insert was installed into an existing old style heatilator metal firebox... with a traditional brick and clay liner chimney... I was told that fresh air intake was not necessary, would not have any real world advantages as it would let cold air into the house along with mice, and would also be expensive to install...
If there is real world dollar savings... I may install for next season.
... well, part of the OAK install process is to put a screen in/on the outside end so this doesn't happen. But again .. it's a closed system. They shouldn't be able to go anywhere. The problem here is, you don't want them building a nest in that cozy pipe, and end up starving the fire because of it. If mice are getting in around the OAK pipe, where it goes through the wall .. that would be a very poor/sloppy install job.
If you put a blanket around the frame, are you not also reducing the air to the convection fan?
