Prince splitter valve leak in detent assy
pybyr
2,300
Adamant, VT 05640
So, today I am using the splitter (which will be a year old in August and works like a dream (Timberwolf TW-HV-1)) and I notice some wetness.
Turns out to be a drip from the control valve, which is a Prince LS3000.
The leak is appearing at the bolt on the detent adjusting screw/ assembly.
Going to contact Timberwolf tomorrow (warranty is a year, so hopefully this will be covered), but in the interest of trying to get to the bottom of what it may need, have pulled up the Prince manual for the valve- see items 11-26 at page 6 of:
(broken link removed to http://www.princehyd.com/Portals/0/products/valves/LS3000Manual.pdf)
Looks like there is a kit available for a replacement detent assembly, but it looks like the kit (list at least) is $53.80. This on a valve that lists for around $100. Ouch
Anyone ever work on one of the detent kits and did you get anywhere by just replacing o-rings and seals?
I've rebuilt seals on spool valves, hydraulic motors, and other stuff but never before ran into a leak in a detent or pressure relief.
Appreciate any suggestions.
Thanks in advance for the help.
I have the same splitter, with about 60+ cords of use on it. Valve had always been dry until this Spring. One day noticed oil when I was done splitting. Have been watching it ever since, and am not getting any more leakage.
I don't have any rebuild experience to share, but would note you need to be pretty clear with them when you order parts - took multiple attempts to get the right hydraulic filter from them (finally brought the old filter in and handed it to them).
Great splitter - was just using it today.
Timberwolf is sending out an entire new valve on their nickel for both part and shipping, along with a label to return the old one to them. Since they're nearby, it should arrive tomorrow. Great service on a great product!
Sounds like you already have all the help you need.;)
New valve was sitting on my porch when I got home yesterday. Pulled the old valve and installed the new. All's well. Tremendously impressed with the service from Timberwolf. They included a label for shipping the old valve back to them on their tab. Doesn't get much better than this!
