Princess 29 reloading wood mid-load question
WoodstovinCT
11
Connecticut
I am in my 2nd month with a Princess 29 insert and everything is going great. I am very pleased with the unit and have the same experience as others report in many of the threads here. My one question has to do with reloading mid way through a load as a top off. Let’s say I miscalculated the prior load and there is 1/3 load left in the firebox burning hot when I am getting ready for bed. With my temp setting this load won’t last till the morning. Or say, all the sudden I am leaving the house for an extended amount of time. Am I able to open the bypass for 5 minutes to cool the catalyst and then top this load off? I think myself and others are worried about the potential thermal cracking described in the manual from the rush of room temperature air.
Any insight on this topic would be appreciated. Thanks!
I do it. Seems like when you open the bypass, that room-temperature air goes straight up the flue, not into the cat. I have a steel cat now, and originally a diesel foil, so maybe a ceramic would've cracked, I dunno.
I still try to avoid it. I have a single-wall connector pipe. If there's still lots of active flames in there when I re-load, I can get some smoke (out the door opening). Much nicer to have a bed of coals which I can rake out flat and then load lots of logs tetris style.
I’ve done it tons of times with no issue. Just watch for flames ripping up the bypass when the door is open. Work quickly!
I do it sometimes. Maybe nothing happens (surely more air goes up the flue than thru the cat.)
But Maybe it does affect the cat.
So I do open the bypass and wait a few minutes.
And I try to avoid doing it in case it does affect the cat wash coating lifetime.
But sometimes you can't avoid it due to timing issues. It is what it is.
Yep, like before you head out to get the new wood load. Also helps reduce any smoking.
Reactions: Tron
I second the “work quickly”.
It drives me nuts watching these YouTubes seeing people reloading hot stoves WITHOUT GLOVES.
Invest in several pairs of rough-outer leather gloves. I wear somewhat insulated with fleece “Tillman 1450 split cowhide” gloves outdoors in the winter. When gloves like these have been used for a while, the insulation gets thin but they’re still perfect for hand protection when handling wood or working with a hot stove.
I’ve got a pair of leather gloves with gauntlets but never use them.
I find these perfect ... https://www.zoro.com/lincoln-electr...4lgwQPkNTRw1zsxZ3Mlvn4nWvV-L9LHAaAv8YEALw_wcB
[Hearth.com] Princess 29 reloading wood mid-load question
Reactions: Burnin Since 1991
Ha yeah, i'm a bare hander. Sometimes we almost get burned.
I do use an "ov glove" from the kitchen to pull the ashpan if i have to do a hot dump.
Welders gloves would be much smarter.
Blacksmiths don't usually use gloves so that might have promoted that questionable habit.
I do it every day on my PI29. This morning the cat was nearly pinned, 1/4 box of hot coals and some charred wood. Opened cat for 5 min or so. Then opened door slowly to allow air to stabilize. Really hot box. Tossed in 3 splits to get me thru the day. Close door, close cat (sometimes I will leave cat open while wood catches fire). Walk away and get ready for work. 20 min later with thermostat on high, wood is burning, I lower thermo, lower fan and im done.
I have a pair of gloves, I don’t use them though. I think the times I have used them was to move a piece of burning wood outside. They’re kind of an emergency thing for me.
I do it daily, load my stove when I get home from work as full as it goes, set burn to low for the night, wake up to a 1/4 of the load burned through around 5am, open bypass for about 5 minutes throw 3 splits in and stove is ready to last until I get home from work around 6pm. Than do it all over again. If it’s not too cold out overnight and during the day(mid 30’s day and high 20’s at night) I usually skip the morning load. This is my second year with my ashford and it took me a whole year to dial it in. The people on this forum were extremely helpful! Lots of good information here.
I use ceramic cats and perform hot reloads when it gets really cold. No problem at all with cat cracking. Of course I open the bypass for a couple minutes before opening the door. I get some smoke rollout, so I move fast and I feel like cold room air is not getting sucked in.
What situation had you removing a piece of burning wood outside? I read that as moving it from your wood burning stove through your house to go outside. I guess/hope you mean you moved a piece of burning wood while outside?
Well, this weekend I was loading about a 6” diameter piece of river birch into the stove. Birch bark catches reeeeaaaalllllly easy. River birch has the bark curling out all over it. So it caught as I was shoving it in the stove. The split was a bit long, I was hoping it’d still fit. It didn’t. I had to pull a piece of flaming wood out of the stove and chuck it into the snow. I wasn’t wearing gloves, but I know where they are if I needed them. It’s not a common thing, but has happened to me before.
All sorts of unexpected things can happen.
Reactions: cr0 and bigealta
