Hello to everyone, new to the forum. Been peeping here and there on certain topics when I see the site come up on google.
I have a problem, and it’s getting me nervous that it’s already the end of October.
I purchased a Summers heat 50-SHSSW01(Englander sub model) stove to heat my 1750sqft home. After messing with the stove and having no luck keeping a fire lit I contacted a certified stove installer and chimney cleaner. He had already cleaned my chimney one month prior and we established good draft with just testing the chimney separate, then with the stove hooked in. The stove will draft but after establishing a strong hot fire, closing the door kills it out. The damper control does nothing to remedy, until the door is re opened for air to enter. After messing with it for a while he and I came up with the same conclusion something with how this particular stove was built will not allow enough air into the fire box to keep a fire going. I will be returning the stove.
The real reason why I am posting is to find out what opinions the forum has on the Napoleon stoves.. they are easy to get in my location and definitely closer to my budget. A simple search shows not a lot of reviews or info on the stoves. Considering the Huntsville 1400ML (leg model) or the Independence 1450.. my house is a 1750sqft split level. Not seal very tightly. Older Andersen windows, average insulation. Needing insight because I need to pull the trigger on something ASAP, and very sorry for the long post rant.
Thank you for the help.
