I'm trying to re lite my propane stove. Its a heat and glo. When I attempt to lite the pilot it not cliking as it usually does. There is not spark. It has been workinging fine for the last few weeks?
Is there power to the unit?
What model is it?
Plug something - a lamp, fan - some kind of small
appliance into the receptacle underneath, if there IS one...
If not, is there a battery powered igniter?
Again, what model is it?
What does the ignitor button look like, is it a round red or black button (not the on/off/pilot) and when you push it in there is some resistance to it?
The other style runs off a 9v battery and I think automatically sparks when you hold in the pilot knob on the valve. Battery could be dead.
What model is it?
What model is it?
Heat n Glo is NOT a model. It's a manufacturer of gas fireplaces & stoves
(& other hearth units, as well).
Is your unit a fire place?
If it is, there's a silver sticker on the bottom right of the
base of the unit - in the valve cavity.
What MODEL is it?
Is there a click when you push the button on the piezo??
If there isn't, replace the piezo.
If the IS, check to see if the wire coming out of the back
of the piezo & that the wire sheathing is in good shape,
i.e. - no bare spots where it could be grounding out & directing the
spark to a spot other than the igniter near the pilot hood...
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
