Ok so I've been up and running with the Quad since nov.  It has an ACC (air combustion control) lever that allows you to set the air wide open for a set period of time and then it settles in at the position you leave it.  Anyway, the lever is no longer working, you should feel some resistance when pulling to the right and that engages the timer and that no longer happens.  My buddy installed his own 7100 and his never worked from the get go.
My dealer is closed today but wanted to know if this should be covered? They are an hour away so i'm sure they won't be happy coming out.
MSG do you know if this has been a big problem with the 7100 and what is the fix? Can they do it from the inside? Reason I ask is that we are about to stone the fireplace in and was wondering if i should hold off.
Thanks in advacne
Thanks in advacne
