Proper height for Pellet Stove Clean-out
beaver011
1
Oregon
Does it matter at what height I place the pellet stove flue cleanout ? Does it need to be near the ground,or can it be up at about 5 feet ?
Any information pertaining to this question would be greatly appreciated.
Your question will probably be answered in the installation manual for the particular stove you want, under the venting instructions. Normally, the clean out is a on tee, so you can run a vent brush into the stove & up the venting, & should be readily accessible.
I guess you can put the clean out where you like.
In most cases, on a vertical install, the clean-out Tee is at the bottom .
Because the most Ash collects there .
Imagine, at 5 feet up, how difficult it will be to clean the bottom section!
Welcome to the Forum
As others have indicated, a cleanout is the bottom section of a tee and is located in back of the stove in line with the vent for a chimney heading up from the stove.
My stove flue exit, then horizontal 3 feet, there is tee with cleanout down, 5 feet of straight flue pipe pointed straight up, then a 90* elbow and tapered exhaust termination.
Bought a HD Craftsman (great sale, last one there) leaf vac / blower to pull air through the low mount cleanout using adapter at leaf vac inlet, it then blows what ever ash it gets out across yard. opening the stove door let it pull anything out of there too.
  • [Hearth.com] Proper height for Pellet Stove Clean-out
You could certainly have another clean out tee above ground like tbear853. I have two , one inside behind the stove, and one outside. What is your layout and plan?
Reactions: tbear853
