So,,, Earth Outdoor came through. They sent the pump and FPHE to me which arrived today. I'm about to install the new equipment, but I had an idea. SO, if I install the pump at the lower point on the furnace it should help with air locking in the pump, but I'm a little concerned about stratification, and loss in efficiency from that. Anyone already have a wood boiler that draws from the bottom of them water tank? As currently setup, the boiler draws water from the top right of the boiler, and returns it to the bottom left. I am considering drawing from the bottom left, and returning to the top right. The furnace is well over sized for my current needs, and will be that way until I enclose and insulate the barn, so currently I do not need to draw every single BTU the furnace can produce from it.
Do not change a thing
What you have is a "circulator" not a pump
it is designed to work with low pressure of 12-18 PSI
strictly depending on the number of stories your home
is and what ever else you are heating.
Please, Please, Please, order a copy of Dan Holohans
paperback book "Pumping away" from Amazon.
It shows the layperson and plumber how and why the
pumping away method works and works well.
If you visit the "heating help" forum it offers the
layman and the plumber alike a wealth of information about
heating systems and methods.
Its easier to pull water through a hot water boiler to the top
and then circulate it as the circulator is not working as hard to
move the water to the heating load of your home and barn/garage etc.
Pleasee go to the heating help forum for more help as they will explain how the
www.heatinghelp.com
It costs nothing to join the heating help forum
Your "circulator" was working just fine the way it was.
Your "circulator" will not air lock as long as the air bubbles
and water are pushed away from the boilers water jacket
as was the case when they installed the circulator at the top
of the boiler.
("Pumps" work better with flooded suction because they
have to deliver very high pressures).
"Circulators" work only to move water at low pressure and only
need 12 to 18 psi depending on how many stories your house has.
Let me tell you a little secret and dont tell anyone else;
When fossil fuel boiler manufacturers build their boilers
they also have to crate them.
They put their circulators close to the boiler at the bottom
to reduce the cost of crating their boilers.
By "pumping away" from the boiler you are making it much easier
to remove air bubbles and not creating greater issues with thermal shock.
You should leave the new circulator as the unit was installed on your boiler
because its easier to bleed the system of air bubbles as the pump is pulling the
water through the boiler and out the top.
Before you activate the new circulator with the system "COLD" pour an ounce of
Dawn Dish Soap in the boiler water and it will break up the air bubbles in the water
and force the microbubbles back through the system to your air vents and your
circulator will no cavitate and make more air bubbles AND you should not have to
chase airbubbles and bleed them out.
This is also explained in the heating help forum as well.
Do not change anything, install the circulator on top of the boiler as it was done
and you will have zero issues. Just be sure to pour an ounce of Dawn Dish Soap
to eliminate the airbubbles. This also raises the PH of your boiler water which will
aid in creating a near neutral PH in the boiler water.
Lleave everything as it is and add a squirt of Dawn Dish Soap and then run the circulator
with out firing the boiler to get rid of the trapped air in the system.
