Is the combustion fan supposed to run at a different speed for each of the heat settings (High, Med, Low)? I have a Castile (bought used) that I am trying to figure out and believe that the combustion fan is not changing speeds when I go from Low to Medium to High. When it is running in Low, the fan sounds like it is running full tilt.
The convection blower changes speeds when I switch heat settings, so I assume that the combustion fan should do the same.
Here is a thread that I started when I first got the stove hooked up and running:
https://www.hearth.com/talk/threads/quad-castile-install-progress.90479/page-2#post-1190328
I appreciate any help.
I think the end of 'start up' might actually be when the igniter turns off, but can't find anything in the manual. I seem to remember something about 10 minutes OR when the green light comes on. I would start worrying when you DON'T have a good swirling air blast in the pot. The combustion fan is quiet enough that I can't hear it change unless I get my hearing aid right up to it.
Cold Start Syndrome!
