We've had a Quad Santa Fe (freestanding) for many many years without much problem until last winter. The combustion/exhaust fan went bad and we purchased a "quick change" replacement (not original equipment) blower motor marketed as PP7620, and touted as way better than the original part. Initially after replacement everything was fine. Howevever we have increasingly since then had this problem with our stove: When running on high, the firepot fills with mostly-burned pellets, yet not quite ash, within just about 4 or 5 hours of cleaning the pot. This causes the dreaded stove rumble. When on low, there is not near as much build up in the pot; and medium there is some but not as much as on high. Prior to the fan change, we would only get this rumble after burning the stove for long periods without cleaning the pot. Now, we can't even sleep through the night without having to get up and clean the pot.
We recently replaced both the firepot gasket and the door gasket. The feed is set to the lowest possible. We have tried many brands of pellets, and our current brand is relatively small in size. Most folks have said that they have had great luck with this aftermarket replacement motor; but we can't help but think it is our problem. We wonder if maybe the motor is failing which is why it did not initally do this and continues to get worse; or if that motor and the Santa Fe just don't do well together. Anyone have any ideas?
. Cleaning the system may perk it up in the short term...
