- Nov 25, 2013
- 57
Hello everyone! I recently installed my Voyageur and it gives some decent heat and looks great however I'm having an issue with the burn rate. It seems to be over-firing, meaning the flames are rolling up over the baffle and wool blanket. I cannot seem to control the burn rate. The burn rate lever doesn't seem to open or close anything and there's no real resistance when moving the lever up or down. It's almost like it's not connected to anything. This may be how it is as I do not know anyone else that has this stove. There's no OAK installed. The plate by the blower fan was removed during installation. I can feel with my hand, a ton of cooler air being sucked into the bottom of the stove by the blower. I'm getting burn rates of 1 hour with an extremely hot fire and big flames. The wood is dry and is hardwood (I also used kiln dried wood for one load). I called Quadra-Fire and the rep said the stove was getting too much air causing the fire to rip at all times. The glass is getting really black. I have used this stove 4 times since I installed it the other day. Today was the first time out of the 4 loads that the insert was blowing smoke in the room with the insert door closed. I guess it's called negative pressure...? I just cracked open my exterior door and it stopped smoking within a second. Does anyone have any pointers or comments, I like the insert and it's throwing good heat but it seems dangerous and is eating wood like crazy.
Thanks!
-Rick
Thanks!
-Rick
, so I can' t talk temps right now, but they are on sale for less than $30 at Harbor Freight.
