I have been using my Quad 1200i pellet stove insert for about a year and have run about 1 1/2 tons of pellets through it.  The stove comes with basic cleaning video, but the dealer is not much help for more detailed info.  Weekly I vacuum the inside and clean the glass.  Monthly I remove the baffles and clean inside by the tubes.  I also remove the small doors at the bottom and vacuum the blower areas.  I don't like removing the small screws that hold these covers, as they seem very fragile.  Am I missing any areas for cleaning or maintenance?
I have about 12' of 3"" stainless exhaust flex-duct going vertically up my existing masonry chimney. The chimney has a flex-duct to chimney adapter sealed to the masonry at the top. I have not cleaned this duct. There is no clean-out and it is a real chore to remove the insert. Since this is a pellet stove, how often should I clean the flex-duct?
I have been reading about sealing the existing chimney near the damper during wood stove installations. My damper was not removed, just opened to provide room to run the flexduct. Since this is a pellet stove, is there benefits to installing this blocking plate and insulation.
