Adjustable double wall adapter or slip pipe?
CTHamNEgger
2
Connecticut
I have a hearthstone shelburne in my masonry fireplace, connected to flexible stainless steel liner. Chimney is 25ft and not feasible to clean from the top.
To connect the stove to the liner/adapter, the installer used single wall stovepipe cut to length. The stove was pushed into place along with the straight single wall stovepipe. I won’t be able to easily disconnect the stove to clean out the flue or the catalysts, and ideally I’d like to reposition the stove a little to get it centered better.
I purchased a double wall adjustable stove pipe (DSP6AL-1 11-18”) but it’s a few inches too long to work for my application. I need something more like 8”-12”, but not seeing that option anywhere.
Any thoughts/suggestions?
Longtime listener, first time caller.
[Hearth.com] Adjustable double wall adapter or slip pipe?
It looks like Metal Fab's 6DWA18 might work. Call them to verify.
Thanks begreen! The way I read the 18 product description is that it will extend another pipe between 6” and 16”. However looking at the 8 , it actually might work to combine that with a 6” section. I’ll give them a shout.
No need to combine; it's an adjustable pipe that has a minimum length of 6" and a maximum length of 16". If you need 8-12, that's all you need.
Reactions: CTHamNEgger
