Couple questions regarding t snout and double wall connection
RMS
10
Pennsylvania
I am going to run an insulated flex liner in my chimney and am not quite sure what to do with this tee snout through the old clay thimble. The snout is 6" and the clay thimble is 8".
1. Should I wrap the snout with insulation, or should it just pass through the way it is? Does the gap between the snout and clay need to be filled, or sealed where it exits the wall? The instructions make it seem as if it is to just pass through, nowhere does it say anything about sealing or insulating it.
2. I want to use double wall stove pipe. How do I make the connection between the snout and the double wall? Is this the best option:
https://www.rockfordchimneysupply.com/products/blk-dbl-wall-masonry-sizes?variant=45671763575064 ?
I called Rockford and they said it slip fits inside of the snout and needs to be sealed with stove cement, but I don't see anything detailing this anywhere, and the guy on the phone seemed like he had better things to do than talk to me so I didn't get to into it with him. Is there a better option for making the double wall transistion or is this the best thing?
Thanks for your time.
[Hearth.com] Couple questions regarding t snout and double wall connection
Thanks for your time.View attachment 350059View attachment 350060View attachment 350061
Are there any combustible materials burried behind that brick?
I don't know how it is framed up back there, house was built in 1980 and I have no way of knowing.
But it goes through a framed wall?
It goes through this into an exterior chimney. I am pretty sure the brick is just a facade, but I dont know what is directly behind it.
I can pretty much guarantee there is combustible material to close to that thimble. So you need an insulated thimble
Can I wrap the stainless snout I have with insulation like a liner, or do I need something else?
You need a ul listed insulated wall thimble
