Ok folks, I am hoping someone might have a suggestion for me.
Quadrafire 7100 was professional installed in 2012. Has worked fine up until this year. We have two switches on the wall for the blower. first is over-ride, which should make the blower run regardless of temperature. 2nd switch is on/off for snap disc. We replaced the rheostat a few years ago and put the switch in because we always ran on high anyway. Everything has worked fine.
This year, once in a while (not every time), we can't make the fan run even with the bypass switch in the on position. The 2nd switch also has to be on (which is it), but the blower will not run even if the stove is very, very hot. The blower is easier to turn on when the stove is cool. it seems that once it gets hot, making the blower run is more of a problem.
I am not quite understanding why we can't make the blower run when the bypass switch is on? Seems like flipping that switch should turn the blower on, no matter if the stove is hot or cold. It always worked in past years. what am I missing? I do have a new snap disc on order. thanks
