Nice testing and some interesting ideas. I especially like the idea that these changes are reversible. I wonder if the baffle plate was cast iron wouldn't it heat up and radiate more heat toward the tubes?
Wachusett said:I do agree, is there a better way to extract/transfer heat out of the stove.
However is this really increasing the heat gained. The total net. difference in temperature output
only appears to be about 3 degrees. (before avg. temp =153.8 after avg. temp=157). I would think the
springs also would cause more friction vs. a smooth tube = less velocity and fan working harder.
Just my 2 pennies, interesting idea though.
SmokeyTheBear said:It is quite possible that the convection fan hardly knows those springs are there.
How big is the fan outlet on the convection fan? Before the reduction the fan was seeing a 12.27 square inch outlet at the stove front.
smalltown said:Nice testing and some interesting ideas. I especially like the idea that these changes are reversible. I wonder if the baffle plate was cast iron wouldn't it heat up and radiate more heat toward the tubes?
Countryboymo said:We need a honeycomb like material that would slide down the tubes that wouldn't restrict airflow much but would have a lot more surface area. It could be slid out and rinsed down or washed in the dishwasher every ton of pellets or so. Wow I can picture it in my head and its made out of that space age material that is super thin but a super conductor of heat.... unobtanium. I apologize, I started daydreaming and woke up at the point of my skin melting from walking in front of the 'pellet reactor'.
Wi Thundercat said:My st.croix has 16 tubes that are approx 3/4"-7/8" in diameter. Seems to me that they used the spiral flat inside the flues on some of the oil burners we cleaned. Imagine this was to improve heat transfer!
Czech said:Venturi Effect? Mine has 10 tubes, two partially blocked as mentioned.
slls said:Would not a larger stove be more practical than trying to get more heat out of a smaller stove.
My CB1200 gives all the heat I need on medium setting.
tjnamtiw said:slls said:Would not a larger stove be more practical than trying to get more heat out of a smaller stove.
Hindsight is a wonderful thing. After dropping over $6K for two stoves plus installation, it's really not in the equation. If you're happy blowing 170 degree air out the exhaust, then there's not a problem. When you talk to Bixby owners and they tell you they can lay their hand on a barely warm exhaust pipe outside, you know that you have something less than efficient.
Because of my floor plan, one stove would not have heated my family room at all, so I needed a second stove anyway. If you buy these things, you have to either be a tinkerer or insane. I like to think I'm the first but don't ask my wife.
tjnamtiw said:Well, I cut the springs for my Sante FE, took initial readings, inserted the springs, waited for the same fire volume and took second readings. The readings are very similar to those I measured on the Castile, which probably is not surprising since their guts are basically the same. Both stoves were given the monthly cleaning prior to readings being taken.
Tube 1 before 170 after 160
Tube 2 before 165 after 182
Tube 3 before 140 after 170
Tube 4 before 140 after 160
Tube 5 before 170 after 175
Tube 6 before 190 after 200
Tube 7 before 145 after 155
Tube 8 before 140 after 155
Tube 9 before 180 after 180
Tube 10 before 190 after 165
Exhaust temp before 170 after 160
As with the Castile, the lowering of exhaust temp shows that less heat was going up the chimney and therefore going into the room. Very little airflow comes out of the first and tenth tubes so those readings are moot IMO and no springs were installed. For tube 10, I can only assume that less heat is available to transfer there since more has been extracted with the previous tubes.
Trail_Time said:I am interested to see further discussion on this. Thanks for taking the time to post.
Have you tried removing the springs from tube 1 and 10 and see what happens to the temps on those tubes?
!!tjnamtiw said:[quote author="slls" date="1291415542
Well I run mine on medium heat and high fan, I can hold my hand on the vent pipe 6 inches from the stove adapter and leave it there all day.
My oil furnace vents at 500 deg F, nothing I can do about that either.
!![/quote]slls said:Yes different stove, 3 heat settings, low ,med, hi, fan settings, low, hi. the fan speed is different for the 3 heat settings, each higher for each mode.
I work with my hands a lot, maybe that's why I can take the heat.
ha ha ha. I have a feeling with the high fan setting on the lower heat levels you are getting better heat transfer.thz123 said:Keep me posted too. I have the Castile too. I like this idea, and might try it. I have wondered why there arn't blower motors for the side walls. I have tried to move air through these side walls, and haven't figured out quit how to do it correct. If I put a small fan blowing under the stove I do get some heat out of the side "vents". Instead of the springs would flat aluminum or copper metal work like someone suggested above? Or I wonder if steel wool in the tube somehow would work too? It would have to be easily removed too, and I don't know how to do that. Great idea!
