Quadrafire Mt Vernon ae wont run
DirtyDave
289
western wa
it keeps giving us a "missed ignition" error
(broken link removed to http://seattle.craigslist.org/est/wan/3433355805.html)
I think they need your folks help
oh boy, where to start...
It would help if they told us the suggestions they tried.
Dirty Dave...is this YOUR stove (it keeps giving us a "missed ignition" error")? Or are we now fixing peoples stove issues that didn't even come onto the forum?
Reactions: kinsmanstoves
No it is not my stove. I listed the link and said I think they need your folks help. I sent them the link for the Forums here.
the knowledge base here is great, and yes I know you can lead an idiot to the table but you cant make him eat.
Okay, stop giving him a hard time. The most likely problem is a burned out igniter. This is especially true if it has the old design igniter with black leads. The new design is made with white leads (according to my service tech). The Igniter is just above the ash pan. You should be able to see it glow during start up. I remember reading somewhere that it is only active for 90 seconds.
Most likely problem is that there was not enough air flow past the igniter and into a proper amount of fuel in the burn pot.
Vacuum issues and that auger system can lead to that. Not having properly adjusted the feed gate can as well.
The auger on that thing can reverse direction or just not move even when the vacuum switch allows it to.
Some of the earlier ones had a number of issues.
That is right including the ever loving flame height and speaking of that ever smart do hickey, there can be cross talk issues in the wiring which makes the stove rather temperamental. Ain't that smart stuff just wonderful?
ETA; I'm with Snowy Rivers keep it simple.
that info was definately wrong. just sayn.
You're right, I mis-read that. What I read is, "IGNITER TURNS ON FOR 90 SECONDS BEFORE FEED CHARGE STARTS".
The igniter is on for a minimum of 5 1/2 minutes for softwood pellets.
Reactions: smoke show
Black lead igniter is the newest one, 300 watt. This one is made for people burning straight wood pellets. White lead igniter is 380 watt and made to light corn and other fuels. The idea is that the 300 watt with latest programming will lengthen igniter life.
