I have an original (1st Generation) Quadrafire Mount Vernon pellet stove that stopped feeding pellets and therefore doesn't light or run.
This actually happened at the end of last winter, so I decided to let it rest, until now.....
I hate procrastinate, guilty as charged !
Side note, last winter I replaced the Control Board.
I have pulled and 'bench checked', the Auger motor, and it works perfectly.
Vacumn switch was tested, by pulling the terminal connectors and jumping them together.
Snap Disc#2 i(which has factor), It should have continuity across it when it's cold. (normally closed, opens when it overheats)
Not much else that would prevent pellets from dropping, so not sure what to do or test next ?
Your thoughts will be greatly appreciated
Thanks..........
!Thanks..........
