So I've had my Quadrafire installed for just over a month now. Took a while to figure out how to light it without smoking the room but some questions for you gurus:
1) The Quadrafire makes popping / popcorn like sounds when it heats up and cools down. If it heats up quickly (with 2-3 pieces of wood) then it is quite rapid, like once per second; if slowly it's more like once per 5-10 seconds. Once it hits a normal temperature it stops. This is after ~15mins with a new load. Is this typical? Seems a bit odd to me.
2) I didn't get the outside in air installed per recommendation because the installer didn't think it's needed. However, I find the air control doesn't do much. When the flames die down I have to open the door. Is outside-in needed in this case?
3) Besides first starting a fire I don't really get what the knob control at the bottom does. It seems to maximize air flow in for starting a fire, but after that do you need to use it? Would it help with (2)?
4) There's a fan control at the bottom. It seems to work well, but I can't turn it off. In manual mode can only turn it down. Lowest setting isn't off(?). In auto mode similar behavior. Is something funky here?
Thanks!
Thanks!
