I'm trying to figure out if the performance of my Napoleon insert (model EPI3) is "normal". I hear stories of people getting much better results than I do (with other inserts). For example, some folks say their living room heats up to 80 (mine, maybe 74). They also say it can heat the rest of the house (we have a split level, so maybe this isn't reasonable without fans).
Of course, every house is different. But still is there a way to measure performance? Below are my details, fwiw.
- Napoleon EPI3 wood burning insert, with ~22' of ss liner, terminates through a ss sealed cap.
- Insert is on a 600sf level, half below grade, of our split level house
- Chimney is exterior brick.
- While I didn't use a block-off plate, I did pack roxul around the liner where it goes into the flue. While not 100% air-tight, I never feel any draft or cold air.
- When the fan comes on, you really don't feel air movement unless your 1-2' in front of it.
- Wood....I try to use locust, fully cured (no hissing sound when burning). I can't really say I keep the insert loaded, so maybe I'm being to tight stocking it with wood. Problem is my pieces are 16-22" and only go in left-right. So hard to stack them.
Thanks!
Thanks!
![[Hearth.com] Quantifying Results [Hearth.com] Quantifying Results](https://www.hearth.com/talk/data/attachments/192/192130-08e480341cbec557fd1842f85a4b6241.jpg?hash=00s_26_d_u)
![[Hearth.com] Quantifying Results [Hearth.com] Quantifying Results](https://www.hearth.com/talk/data/attachments/192/192131-3adedeea97dd830cf280913462e6b72c.jpg?hash=qGYCt4CKp5)
Feed that baby what it wants, and lots of it!!
