I have a new PE Neo 2.5 non-cat insert. 6" insulated flex liner, 15' flue. The Neo only has primary air control. I am still learning my insert. I am burning soft maple (I think) because that is all I have seasoned for this winter. It is dry according to my MM 10-15% and it catches fire before I can even finish reloading at times. So 20-30 minutes after I reload, I have a raging inferno going. I start to close the air down in small increments at a time, approx. 25%. Still Raging inferno. I wait another 5-10 min and close the air some more. By this time, my glass starts to turn hazy. Starts in the top corners then continues down and almost to the bottom middle, like a flat “U”. After 5-10min, I continue to turn the air down to 2/3 to ¾ closed. By now, the firebox isn’t a full raging fire but mostly secondaries. And not the "northern lights" kind. It looks like there are 62 mini torches on the top of the firebox pointing down. However, the glass is more dirty than hazy and getting dirtier. This is about 40-45 minutes after reloading on hot coals. I experiment some more and open the air back up all the way. The glass goes clear in less than a minute. What is going on? Why I am getting dirty glass with secondaries going like that? If I leave the air all the way open, I have nice clear glass for the whole burn cycle but my firewood is burned down to coals in 1.5 hours. I have kept the air closed down other times and some of glass gets burned clean but not all of it and not all the time. I am sure with better hardwood firewood and larger splits, I will get longer burn times but for the time being, I am just trying to understand what is going on in this particular instance. Im guessing my firewood is burning too hot too fast before I can turn my air down properly? My apologies if this has been previously discussed. I really try to search and read all prior posts before bugging you all.
