Question about snout install through chimney.
Tdognc
4
N.C.
Hello,
My wife and I are looking to have a new BK installed for our chimney. The previous owners had an old Buck stove that was drafting excessively, had signs of over firing, and the space it was in wasn't up code so we decided to renovate the entire space at the same time. The BK sits higher than the buck stove so the old hole will have to be patched and a new hole will have to be drilled above it, but due to the renovations the chimney now sits off center to the left of the alcove it will be in. I was wondering if it would be possible to drill through the brick at an angle to have one end of the hole line up with the inside of the chimney while the outer portion lines up with the center of the alcove (offset on the right of the chimney). Would this even be possible, or would I just have to have the hole exiting the center of the chimney wall and be offset to the left in the alcove (we plan to tile over the surrounding walls so the chimney would not be visible at all). I have attached a photo of the space with a rough sketch overlaid and a crude diagram if that helps.
Thanks,
Tdognc
[Hearth.com] Question about snout install through chimney.
First, make sure the chimney is safe, clean, and the liner appropriately sized for the new stove. If it is, I would not move the thimble, especially if the draft is relatively strong. The offset is fine, it may helpin slowing down the draft a little.
Angling the snout to have a longer length in the wall would significantly weaken the wall.
What does that wall hold up?
Yes, and if the flue tile is rectangular clay and not a stainless liner, then hitting it on the corner would be a big can-o-worms.
Reactions: stoveliker
We are, we are getting a new flue installed at the same time appropriate to the stove (double insulated 8" for King 40).
The wall in front of the chimney is not load bearing and will only support the tile I place on it.
The flue will be a new stainless liner. We don't trust the previous owners to have done a proper job with everything else that was out sorts with the stove and I know they went with whatever was the cheapest option possible.
So it's not a concrete coring that would need to be done?
And with a liner you can rotate the snout.
If the wall doesn't support anything, and your sense of aesthetics is demanding the hole to come out elsewhere, then you could do it.
Though it'll look awkward with a shallow entrance angle, and the larger radius of the 8" piping. You'll have a long transition where the pipe enters the wall. You'll need a big collar to cover that, which, to my sense of aesthetics doesn't look great either.
No, no concrete, just cement board over the brick with tile on top. As for the transition for the pipe, I believe you mean that with a shallow angle the hole would look more oblong and stretched laterally into an oval shape if you were looking at it straight on?
Yes
